LumpyFPV
- Aug 2, 2024
- 0
- Eagle Point, Oregon
- Ranger XLT
I was pulling the bearings and seals on the rear axle to replace them since I was replacing my differential's spider gears. Left side was no problem; bearing puller on a slide hammer, came out quick and easy. Bearing went in without much hassle. Left side though? I didn't even know this was possible. I got the seal out with ease, got the bearing puller in there, a couple pulls with the slide hammer and shit flew EVERYWHERE. Rollers all over, cage in bits, pieces of the race scattered about.. then I saw it. The pressed bit of the race is still there. ****. So much ****. I tried heating the tube and using the seal puller, no bueno. Then tried to get a chisel in there and I marred up the inside of the axle tube. You can see the damage and I suspect that's going to leak now regardless of whether or not I can get the race out and a new bearing in.
My question is this; is it salvageable?! I could get someone to weld a bead around the race and pop it out probably - I'm no welder and I don't have the equipment - but is the damage to the tube too much? It's pretty bad.
Another question - any other way you can think of to get that race out other than welding?
At this point I'm looking for used rear ends since I imagine the tube is fucked, but I'd really like some insight from someone with more experience than me with this stuff.
If I do end up going with a new rear end, from what I understand most Ranger models and years from 1991 on - 8.8 and 7.5 - are interchangeable without any modification. Is that correct? I'd like to keep my 10" drum brakes but other than that would I need to modify anything?
I'm a long time lurker and first time poster. Thanks in advance for any assistance.
