- Jul 21, 2014
- 74
- Bama
- Ford Ranger XLT
- Engine Type
- V8
- Engine Size
- LS
- 2WD / 4WD
- 2WD
- Tire Size
- 28x10.5
I have a 1990 Ranger that I'm in the process of building. I plan on using a stock width 1992 Explorer 8.8 (plus 1.5" each side).
I'm attempting to shovel a 17x8" with 5.67 backspacing (30mm offset) in rear, and use 15x6" with 3.5" backspacing (0mm offset) in the front.
Normally I'd install the rear then figure out what I need backspace-wise, but in this case I can't. I want the rear tire to be tucked inside the fender well (rolled).
The wheels are made to fit 1998-2004 Mustangs, if that helps.
Will it work?
Will it work?
