@pjtoledo you got me on the right path. Thank you
@don4331 I have the calipers in hand
My calipers call for a 11.75"-14.00" with a thickness range of 1.15"-1.35"
I really want to fit a 15" wheel on the truck. Here's a comparison of one I found and it's about 50% cheaper than the crown vic rotors I bought.
Crown Vic
Part Number
66744
Part Description
Disc Brake Rotor
Sub-Brand
Specialty - Street Performance
Grade Description
Specialty
Brake Rotor Casting Type
Vented
Brake Rotor Diameter, Outer
12.440 in / 315.976 mm
Brake Rotor Thickness, Discard
1.014 in / 25.756 mm
Brake Rotor Thickness, Nominal
1.105 in / 28.067 mm
Brake Rotor Type
Conventional
Center Hole Diameter, Minimum
2.826 in / 71.780 mm
Height, Overall
2.590 in / 65.786 mm
Performance Level
Standard Performance
Surface Finish
Plain
Packaged Weight
23.0000 lb
Part Number
7036R
Part Description
Disc Brake Rotor
Sub-Brand
R-Line
Grade Description
Better
Vented
11.750 in / 298.450 mm
1.180 in / 29.972 mm
1.245 in / 31.623 mm
Brake Rotor Type
Conventional
3.252 in / 82.601 mm
Height, Overall
2.635 in / 66.929 mm
Performance Level
Surface Finish
Plain
Packaged Weight
19.8000 lb
Wheel Bolt Circle Diameter
4.500 in / 114.300 mm
Wheel Bolt Hole Diameter, Maximum
0.653 in / 16.586 mm
Wheel Bolt Hole Diameter, Minimum
0.645 in / 16.383 mm
Wheel Bolt Holes, Primary
5
Country of Origin
CN
https://www.rockauto.com/en/moreinfo.php?pk=391222&jsn=714
Part Number
780540
Part Description
Disc Brake Rotor
Sub-Brand
Specialty - Truck
Grade Description
Specialty
Vented
11.896 in / 302.158 mm
1.039 in / 26.391 mm
1.102 in / 27.991 mm
Brake Rotor Type
Conventional
Center Hole Diameter, Maximum
2.837 in / 72.060 mm
Height, Overall
2.524 in / 64.110 mm
Performance Level
Surface Finish
Plain
Packaged Weight
17.2000 lb
0.656 in / 16.662 mm
5
Country of Origin
CN
VEHICLES
