1990 2.9L Manual - Stalls in First gear, won't move its own weight.
Boulter
4
Canada
Compression looks like this...
212.0, 186.0, 193.5, 186.5, 199.0, 193.0
Seems high, perhaps we did something wrong. Used Mighty Vac Digital Compression Tester MV5532. High is ok? Low is bad?
Brain75
273
Colorado
was that wet or dry?
another thread here folks discuss what seems reasonable:
the TL/DR; version is gauges have a lot of variance - do you have a history and feel for that specific gauge?
DIFFERENCE is also a biggie - your high-low = 26 if I did the math right...
and MINIMUM is also a biggie, over 90 so you have enough compression to actually ignite when cold.
My hunch is still that your engine is fine, and your issue is in the drivertrain (somewhere between clutch and tires) not engine. I'm betting transmission from your testing so far.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
TRS 25th Anniversary
6,048
woodhaven mi
FORD mostly
BIGGER
sawzall?
disconnect the map sensor
rusty ol ranger
2.9 Mafia-Don
8,711
Michigan
177 CID
Yeah thats extremely high.
Usually 120-140ish is what most guys are finding.
Boulter
4
Canada
Disconnect while checking compression? We have replaced the MAP sensor, it wouldn't run with the old one in. Swapped it out for a new one and the truck now runs.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
6,048
woodhaven mi
FORD mostly
BIGGER
sawzall?
disconnect it and see how it runs. and you are sure it is getting clean vacuum signal?
Boulter
4
Canada
Latest update...rear drive train rolls freely
Did koer code test and got 12, 13, and 22.
Wouldn't start after last, removed and cleaned plugs and now able to start. Two plugs have lots of carbon.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
6,048
woodhaven mi
FORD mostly
BIGGER
sawzall?
the vacuum line going to the map sensor is good? straight vacuum?
idle air control and carbon plugs. how bad does it smoke?
really smacks of no load sensing and shit injectors. which is map on these
Rick W
October Truck of The Month
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
