Munchie1615
- Apr 17, 2021
- 4
- Gainesville, FL
- Ford Ranger
Alrighty guys, here it goes. This story begins with the purchase of 1990 2.9 V6 Ranger with automatic transmission. It ran when I bought it but needed exhaust, it was cut off at the cat. Also, the guy that sold it to me told me said that the vacuum wasn't working at the connection going off of the manifold to the FPR (that I now know). Regardless, I drove it home that night.
It needed a battery, I put a new battery in. Found out the alternator was bad, I replaced that. Tested to make sure the new one was charging the battery which it was. All seemed gravy. For the exhaust, I put on the dynomax system and replaced the cat and filled some rice krispy welds at the y-pipe. I did notice they filled the hole for the O2 sensor, but I didn't think this would cause a huge issue... The truck was running decent enough for me to move onto the next task. I wanted to do an oil change and a coolant flush.
Oil change: Found the oil was milky, making me think there's a head gasket leak. I completed the oil change adding new oil and a new filter.
Coolant Flush/Head Gasket Situation: I used the Blue Devil cleaner and performed the coolant flush. I also purchased the Blue Devil head gasket sealer as well (the one where it has to idle for 50min). I did this per the instructions on the bottle. After letting the truck idle for 50min I let it cool down and I replaced the thermostat with a new one and tightened everything up. The trucks exhaust looked way better than it did before and I feel like the head gasket sealer worked the way it was supposed to.
I took the truck for a spin up and down the road and as I was getting ready to pull in the drive it stalled out and I haven't been able to get it to start again since.
Here's what I've done:
50/50 Test:
1) Does not start on starting fluid
2) Tested for spark, looks like I have spark per the test light
Compression test:
Cyl 1 = 165
Cyl 2 = 165
Cyl 3 = 170
Cyl 4 = 160
Cyl 5 = 170
Cyl 6 = 165
Fuel Pressure: 42psi (after a couple KO cycles)
Fuel Pressure after 10 min: 34psi
I've tested/replaced:
1) TFI - I thought this HAD to be it, from all the threads I've read and videos I've watched. After replacement, still same story, cranks and won't start.
2) Distributor Cap -- Replaced this as well as the rotor, the "button" on the old cap had a piece out of it and looked compromised.
3) Spark Plugs and wires -- Replaced all the plugs, and wires (yes, I've checked the wire locations to make sure I installed them in their correct location). Even after distributor cap, plugs, and wires still the same result - Cranks and no start
4) NOID light testing -- tested the IAC and all of the injectors to ensure the pulse was firing, this tested GOOD.
5) Engine Coolant Temp Sensor (Outside temp: around 67 degrees F) -- ECM pins 7 & 46 - tested at 43,900ohms -- Tested at the sensor 44,600ohms
6) Air Charge sensor (Outside temp: around 67 degrees F) -- Tested at the ECM pins 25 & 46 -- tested at 43,600ohms -- Tested at the sensor 44,900ohms
7) Checked Timing: Aligned the TDC line and checked the rotor position it was dead on the #1 spot when I checked under the cap
For s*its and giggles I put the original TFI back on to see if that would do anything, since I've read that aftermarket TFI's can be unreliable, I know I need to do the TFI troubleshooting guide that I've found on here - I plan on doing that tonight/tomorrow morning. Still results in a crank and no start.
Today, while trying to test voltage at the Air charge sensor with the KO, I connected one lead of my multimeter to one of the paperclips in the back of the connector and I heard 3 random clicks smelled electrical smoke and found my ECM blew a capacitor. I went to the junkyard today, found a 1991 Ranger with Auto trans and grabbed the ECM out of it -- Reinstalled in my Ranger and I have lights on the dash again but still just cranks and no start situation.
What else am I missing? One of the most helpful videos I've watched was the "I picked Frank Fritz's 1986 Ford Ranger" by Watch Wes Work -- I thought I might really be onto something with the coolant temp sensor like his, but now I'm not sure. I have the 1990 Ford Manual, the 1990 Ford Electrical and Vacuum troubleshooting manual, and the Haynes manual. I have combed through everything I can think of so far.... What the heck am I missing!?
Also, I keep the battery charged up and always check the voltage before I do any testing, it's always around 12.4-12.6 volts. Also, I purchased an OBD1 reader and it hasn't thrown any codes, I checked this before it stopped running as well and never had any codes. I don't know if because I disconnect the battery when I'm done messing around with it if that's why no codes are present or if it just doesn't want to tell me anything.
I think that's everything so far..
This is my first "project" truck, I really want to get this thing running again...
Mary
50/50 Test:
Compression test:
Cyl 1 = 165
Cyl 2 = 165
Cyl 3 = 170
Cyl 4 = 160
Cyl 5 = 170
Cyl 6 = 165
Mary
