Jnic
- Oct 10, 2021
- 0
- Missouri
- Ford Ranger
- Engine Type
- 2.3 (4 Cylinder)
- 2WD / 4WD
- 2WD
I am having this happen on occasion and now almost every day. It seem to be happening when it's been sitting for a few hours or overnight. If it was just running I can usually still start it but it takes quite a bit of cranking. Just hooked a fuel pressure gauge up last night. Running it's at 30 psi, if I unplugged the regulator vacuum hose, it jumps up to about 40 so that is working. If I go to prime the fuel before starting it will barley go up, and I have to cycle the key a few times for it to get up to around 40. So if I cycle the key a few times then go to start it, it still wouldn't start. Here is a video I took of that:
https://youtube.com/shorts/yRgs5hls6dg?feature=share
Here is a video of just what it did before I had a gauge hooked up after it had been sitting overnight .Sometimes it does like this and tries to fire, other times nothing. But like I said if I go pop start it, it starts. Now it doesn't actually "catch" right away. Once I let the clutch out it kinda sputters a but before it stays running.
Another thing to mention is after priming the fuel, it will slowly start dropping. Maybe 5 psi in about 5 minutes. I'll have to check again in a bit, but it definitely wasn't holding pressure entirely.
So all and all with what I've tested so far I'm thinking it had 2 issues. I'm thinking possibly a bad fuel filter causing it to take several key cycles to build enough pressure. Then I'm thinking something with the injectors causing it not to fire even with adequate fuel pressure.
