JayDeavor
- Mar 16, 2022
- 10
- PA
- Ford Ranger
I am at my breaking point, I have a 1989 Ford Ranger 4x4 with a 2.9L engine that probably should have been in its grave yard but I have a soft heart for the first generation Rangers. I practically rebuilt this whole truck from front to back. The truck was pretty beat up from a young kid that had it before me. It was okay though because I had an 1989 Ranger myself that was getting way to rusty for the road, but I had a ton of new parts that I swapped over.
I didn't like the color of the newer to me trucks interior so I swapped everything including the complete dash itself. I even went as far as changing all the wiring except the harness that operates the rear lights and the interior harness that operates the door jam switch, rear speakers, dome light and cargo light. All other wiring was swapped over from my daily driver. Basically everything was swapped from my daily driver to the newer truck even the windows.
The complete surgery went very well until it was time to fire the truck and I didn't have any power to the fuel pump. After making sure the relay was good I remembered I forgot to hook up the ground wire from the relay. Since the ground wire for the relay was broken off of the ground wire, I ran a new wire from the relay to the core support right by the battery with the other grounds and everything seemed to go good until I noticed the fuse blew for the Parking Lights, License Lights, Engine Compartment Lamp, Lamps on Warning. When replacing the fuse with a new on it popped again right away so now I know I have a short to ground somewhere..
This is where I am about to give up. I started in the rear unplugging lights working my way to the front. I just can't figure out where my short to ground is. I put an old license plate socket and bulb into the fuse spot to try and find this short to ground no matter what I did the light just wouldn't go out. I went as far as pulling the complete dash out of the truck and checking the wiring the runs from behind the fuse box. The fuse #10 that has the short has a light brown with black tracer and a thicker dark brown wire. The light brown with black tracer goes up to the headlight switch and the dark brown wire goes to fuse #11 (Speed Control Amplifier & Radio, All Wheel Drive) (Now the Radio has not been installed in the newer truck yet)
After checking everything I could think of, I threw the complete dash up on the engine bay and hook up the main harness just so I could have and easier time than installing the dash back into the truck. I stilled had a hard short to ground so I just started unhooking everything that had a plug. All plugs on the back on the dash pad, All plugs in the engine bay on the driver side and also unplugged. I noticed when I remove the ground wire on the fender well right by the cruse box the light goes a little dim but doesn't go out same goes for the ground on the drivers side that is connected to the core support. The light goes dim but doesn't go out. I tried the headlight switch from both trucks and it is still the same thing, nothing changes.
I am pretty much at the end of my ropes. The only thing that I can see that is still hooked up to the main harness is the wiring that runs from the main harness across the front of the truck over to the power distribution box. ( Yes everything at and around the PCM is disconnected ). When I pull the 40 amp fuse for the headlight out of the power distribution box, my test light goes out. I did not open the harness that runs from the main firewall across the front to the power distribution box.
Am I even going about finding this short to ground the right way? Should I open the harness that runs to the power distribution box and look around in there? I am needing help to get this part figured out so I can get this mess looking like a good truck again.
Thanks in advance to everyone
Jay
in the picture you can see the dash is on the engine bay and in the red circle you can see my short to ground testing light is still on even though everything is unplugged
Jay
