Steve1950
- Nov 30, 2020
- 2
- san diego
- ford ranger
Hi Guys, I am "helping" my 40 year old son with his 89 ranger. Lots of miles on this jacked up truck. Not jacked up bad but literally jacked up. The body is lifted making it hard for an older guy like me to get inside. Anyway I like to borrow the truck every once in a while so I try to help him when it needs work. It broke a while back and we determined it was the crank position senser. We fairly rushed the job and didn't get the sensor positioned right. The cam shaft appears to be one tooth off as well. My son said timing was advanced causing pinging and last time he tried the old ranger wouldn't even start. I went over to his house today put crank on TDC and cam is off the mark a little. Also looks like the crank position sensor has no clearance between the outer vane of the crankshaft pulley hub. The little red plastic positioning piece probably got swept up and thrown away so I can't use that. Can I just make sure the sensor is positioned evenly on both sides with a feeler gauge or piece of thick paper. I am fairly sure it is to tight now. Does the auxilary shaft have to be in any particular position? Should I get a special tool for moving the belt tensiorer or will a big screw driver or small crow bar work?. Mostly I would like some tips on that sensor install but any other advice would be appreciated. This is my first question and I hope I can figure out how to read any replys. I am planning on heading back over tomorrow and putting it back together. Thanks Steve ps I bought a new belt and tensioner to put on. Is it OK to reuse the old tensioner spring. My Dayco cheapo tensioner had no new spring.
