- Jan 11, 2012
- 13
- Washington State
- Ford
- Engine Size
- 3.0
Need some help guys. The end bushings are worn out on my sway bar, can find replacements online but I stumped the very helpfull tech at Jackit because the sway bar is a solid 1 1/8" tube with no end link. Runs from side to side through a crossmember which has two split bushings evenly spaced, and ends at the frame as a straight tube through a 2" tall bushing. The bushings are held by a u clamp inside the frame that also holds the lower shock mount on the outside of the frame.
It appears that Daystar makes an end bushing that may work, but I dont want to gamble the 31 bucks if I dont have to.
Ideally I would get the center split bushings as well.
Anyone change out these bushings and have a source?
