1988 Ranger Restoration - Keeping a Promise
G8orFord
445
FL
4.0 SOHC S/C
Just the right size to touch the ground.
12 valve 2.9l, 21psi, stock internals, dynos 535hp at the rear wheels ๐Ÿ˜œ๐Ÿ˜˜
1:40 or so to be able to hear it.
I get it. You're doing it right as best as I can tell, but 21 psi is ALOT for a gasser. I realize tuning can help a lot with today's electronics and fuel injection though. I just don't think stock internals will not last long at that level. What crank are you using? Surely not the cast stock piece.
Rock Auto 5% Discount Code: 7FA902352B4C01: April 5th, 2021
PetroleumJunkie412
2.9 Mafia
4,727
Pittsburgh, PA
2.9l Trinity
Yuuuuuup, the stock cranks are forged, so that one's being reused.
G8orFord
445
FL
4.0 SOHC S/C
21 pounds is small peanuts for a gasser nowadaysView attachment 42984
Maybe for a modern engine or a purpose built engine designed with that in mind, but not a 30+ year old design never intended to be boosted. PJ seems to have all that figured out though.
G8orFord
445
FL
4.0 SOHC S/C
PetroleumJunkie412
2.9 Mafia
4,727
Pittsburgh, PA
2.9l Trinity
Cool, didn't realize they had factory forged cranks. Most are not.
Yessir. Iirc factory truck crank mains and clutch pilots very different from merkur block to ranger block. Pruett and uk forums show a few differences, and both mention truck crank is stronger. @Stroker and @DPDISXR4Ti may be able to shed some light here.
IDK wtf kind of cast the factory pistons are either, but holy crap are they strong. Rod bolts are weak point. $60 in ARP bolts fixes it. Morana himself told me that the Eaton m122 was his blower of choice for the 2.9.
I'd recommend to anyone to call him if you're doing a build on the 2.9 or 4.0. he's in his 80s. Pick his brain while you can.
Forum Moderator
5,064
SW Iowa
sgtsandman
Aircraft Fuel Tank Diver
Forum Moderator
2,828
Aliquippa, PA
2011 & 2019
Ford XLT & FX4
4.0 SOHC & 2.3 Ecoboost
31X10.5R15 & 265/65R17
I work in fuel tanks for a living. Don't judge me!
Iโ€™d be running too if I had a Dodge coming at me. It might not be able to stop...
McWillies
4
Ford Bronco II
If I was less practical and had a couple more loose bolts in my cranium I'd follow in your footsteps... This thread is a gold mine and you sir are the miner. Have the top end of my 2.9 pulled off because I blew the head gaskets and I'm waiting for the heads to get done at the machine shop... My upper intake manifold keeps whispering in my ear about how it wishes it and the lower manifold could flow better :shok:
PetroleumJunkie412
2.9 Mafia
4,727
Pittsburgh, PA
2.9l Trinity
Side note.... I may have stumbled across the oil pan mod of all oil pan mods.....
๐Ÿ–•๐Ÿฟ๐Ÿ˜˜
snoranger
Forum Moderator
ASE Certified Tech
4,557
Jackson, NJ
'79,'94,'02,'17
All Fords
McWillies
4
Ford Bronco II
Definitely added 30 horsetorques with that mod... Don't wanna high-jack your thread, but do you or anyone else have experience with Promaxx Performance heads? Have to buy two new 2.9 heads and I'm torn between them and King. Both companies have new heads with an "improved design." The Promaxx's are cheaper but I can't find much info online about them. Under the "about us" section on their site it says they started up in 2012. I know World Products used to be a common upgrade but they don't make 2.9 heads anymore. From what I've read King has a good reputation. I'm buying assembled heads, so I'm not just worried about the casting quality, but the quality of the moving stuff too. Thanks in advance y'all.
Edit: Just did some looking around and went back in your thread to see what heads you're using. I see it's Promaxx. Can you vouch for the valves, springs, and retainers as well? I'd like to not spend the $650 for Kings if I don't have to, but I will if the Promaxx's aren't worth dealing with.
PetroleumJunkie412
2.9 Mafia
4,727
Pittsburgh, PA
2.9l Trinity
The valves, etc that came on my Promax from J&C Enterprises are beyond garbage, and partly responsible for my rebuild.
J&C recycles used valves, springs, etc from old heads and drops them directly into new ones. Three of my valve springs were DOA.
Promax themselves are fine, just need finishing work. No idea about King tbh.
