1988 Mitsubishi FM146 sychro rings
Rangerang
I need 1st & 2nd sychro rings for a 1988 Ranger, 4wd, Mitsubishi FM146 tranny; they look identical. I ordered p/n E5TZ-7107-C from eBay but they are 1/3 too large. The orignal rings will almost fit through the ones that came. Can anyone give the correct p/n and/or a source?
I got the E5TZ-7107-C number from a pdf document that covers FM145 / FM146 / FM132.
I just called my mechanic & he says the original rings measure 3-1/8" outside tooth to tooth, the new ones measure 3-5/8".
Assy number is: E87A7003AEA.
Build code: 089042 .
Junk Collector
Truck of Month
4,799
Rapid City SD
Usually they come with bearing kits... I believe those rings are the same. You may be able to buy them from cobra transmission or motive gear or a few other places separately. I don't have my parts book handy, can't verify that the parts you got are wrong.
gearfather
15
twin cities mn
you have the right part number for the 1st gear blocker, the 2nd gear blocker is a e5tz-7107b, but only the key width is different, the o.d. is the same.
