Here is the engine running during break in, pretty smooth for this portion although it was sputtering or something, seems to be running rich, timing nor idle have been set.. The fan control sensor was not doing it's job so I had to run the override switch the whole time but the engine never went above 190. After it was shut down I did notice some fuel coming from the throttle body... Not really sure how or why? Guess I will get timing set and idle adjusted then see where I am at from there. I do have a check engine light on, no clue what for or how to check it.
https://photos.app.goo.gl/sazM7UYrSrdAmU1d9
Well it sounded pretty good... vitals were good too. Fuel dripping from the throttle body is a bit concerning... the upper intake had to have been soaked for that to happen. It has to be coming from a sort of "intake stand off/reversion". Which is really the intake valve coming closed fast enough to send a portion of the air/fuel mixture back up into the intake. Then holding at constant speed... that fuel clings to the walls of the intake in lower velocity areas... and it appears in your case it's enough to let it puddle and actually drip from the throttle body. I'm sure if it was leaking there... it was also running into the cylinders to some extent. I guess ignition timing might have something to do with it. Starting the spark a bit to early and the pressures in the cylinder could amplify the situation. Maybe dive into some internet descriptions and see if you can find some answers.
Also look in the Tech Library for pretty much everything you need to know about pulling codes on these ODBI systems.
6 or 8 inch? I just got some Corbeau Moab seats. When I get those in the Tuffy is next. Although I like RumPunch's Millennium Falcon console better!
I think this might have been meant for me?
I went with the 6 1/2 inch wide... after measuring distance between the seats I didn't see anyway the 8 1/2 wide console was going in there and let the seat slide un-interfered.
I'm also jealous of your new seats... they're on my list. I opted for a set of covers temporarily until I get the other "have to haves" out of the way. Be sure to post up your install... I need to see it!
