GingerKing13
- Dec 2, 2016
- Reaction score
- 9
- Location
- Defuniak Springs, Fl
- 1988 Super Cab
- Make / Model
- Ford
- Engine Type
- 2.9 V6
- Manual
- 2WD / 4WD
- 4WD
- Total Lift
- 2 inches
- Tire Size
- 31x10.5xR15
Hey gang,
Ive had this 1988 2.9L 4x4 EXT CAB Manual for 7 years and have never been able to use more than 10.5 Gallons until the gauge shows empty and she sputters to death. I swapped the fuel pump out and I still have the same issue.
The first pump I had in there was the straight one that just hung straight down. could only use about 10 Gallons before the gauge read empty and it starved of fuel.
The second pump I tried was the one that makes two bends (45 and 45) and still can only use about 10 gallons before the gauge reads empty and starves of fuel.
I currently have the one that makes two bends (45 and 45), do I just have it rotated the wrong way? Does it matter which way this pump sits in the tank (facing rear vs facing front)? I am tempted to pull the sending unit that's in there now and bend it down to reach the bottom of the tank... Have yall every heard of anyone doing this?
The attached picture of the tank is model I have.
The Fuel pumps I have tried are below with Part Numbers attached pictures:
DELPHI HP10164 (45 and 45) Currently in the tank
DELPHI HP10166 (straight)
Please help me figure out which pump it needs to reach the bottom so I can finally go on some long trips I want to do.
Thanks guys!
Thanks guys!
