corerftech
- Apr 22, 2021
- 84
- Memphis, TN
- Ford Ranger
After a number of discombobulations, direction changes, mistakes- I have finally arrived at the point where significant work will be started on my 1987 std cab/bed Ranger.
I found a 51,000 mile 2001 Exp engine on a shelf, from 2005 dated wreck, immaculate. I have procured that engine, an M5R2 with 80k miles from a similar fate and storage length, front end and fuel system rebuild, a TL 8.8 explorer disc rear, TL rebuild kit, an 87 clutch pedal assembly (truck is auto as built), microsquirt for ignition handling, Holley contender DP manifold.
The truck has a two piece front end now thanks to BobbyWalters insight.
My intention initially was to have a family hot rod but I said to heck with family since my adult sons have all abandoned me for the most part to proceed with their own lives. My wife won’t drive it but once. So creature comforts are being removed as early as this weekend. The whole dash is leaving. Replacement will be aluminum thin sheet fabricated leaving my tall body lots of room. Gauges and switches, that’s it. A JBL flip 4 will provide tunes but not likely over a B303 lope on flow master delta 40s with turn downs.
My wife fell in love with the bench seat and blue interior. Gone!
Two race seats will be procured at some point. The new key is weight reduction. ET reduction by weight control, not HP.
I will be selling the turbo previously acquired. Turbo just won’t fit simply enough, cost of header fab is exorbitant. I gave up. Rather, last week I picked up a Paxton Novi1200SL kit for 05-06 Mustang 4.6 and will cannibalize if. Blower has 6000 miles on it!!! There is a story behind the blower. I paid very little for it, about what a set of headers would cost for the turbo application. It supports 775 HP as trimmed and that is far in excess of my target.
The GT40P heads stay, new springs will be installed. Cast manifolds will remain for early service unless budget improves.
This truck will be limited to 450hp, period. It will run initially E85 via ATM Innovations 650 billet carb. Angela Neely (ATM) has committed to update fuel when the truck moves to Hydros Ethanol (E98 for short).
Bumpers will be aluminum thin wall tube to satisfy legal demands. Painted black they will increase weight reduction.
Spare tire frame goes this weekend.
The plan-
Cam/valve spring updated only 2001 Windsor. If budget permits maybe pedestal rocker upgrade and push rods.
Oil pump shaft update.
SFI balancer.
Explorer driver FEAD will be band sawed to allow the upper section to be welded to the Paxton/Vortech mount plate. The stock Paxton idler moved on plate to facilitate ONLY alternator (stock position), idler, Paxton). A tensioner will be added to the plate as well (stock fomoco). The passenger fead removed and two aluminum billets machined to make the “three hole” base for alternator.
So FEAD- gone.
Meziere external water pump with fittings and plate installed to free up center of engine.
A Volvo EPAS was procured and will live in back corner of bed, battery located at opposite corner.
New stock fuel tank in hand, POR 15 treatment forthcoming to better protect from E85. Later the spare tire region will have a fuel cell installed. At that point the rear end will be narrowed, a four link installed. Budget and parts acquired prior to the plan change to “pure go fast” mode are forcing me to make the rear end and fuel system mods later.
I intend to procure a Jericho DR4 to serve shifting needs.
For now the low mile M5R2 will be the weakest link and the truck will be preserved while it is in service.
advertisement: if someone finds a DR4 trans, any gear set, for sale at a GREAT price, please keep me in mind. The transmission is critical for the truck but….. as new is also wicked expensive by the time an SFI housing is procured, and the balance of clutch and shifter. Very much worth it though.
Trans tunnel will be cut this month, out completely. I have to fab a way to make it removable, serviceable, as I won’t fight bellhousing bolts.
Ala BobbyWalters, radiator will be mounted on the frame as the core support has been deleted. Firewall to be patched for both some cancer remediation (the only spot is the heater box region) and for heater/AC delete.
I considered a MII front end and I am poor so not happening. Plus I think it’s actually heavier with the thick crossmember.
I have a pile of suspension parts here from RA to restore the entire front end.
TheATM carb will be fed by a Walbro 255, aeromotiveA1000 regulator, boost ref.I have Russell alum fuel lines to run in tandem.
Yes aluminum lines with ethanol.
There are a few things that remain like whee fitment, tires, etc.
Ultimately the target is sub 2500 lbs with drive and 450hp.
Power is easily achieved. Staying below block split area but a dead hook at that power will likely be the end of the engine anyway.
I like straight cut gear whine, blower howl, boogedy-boogedy of the B303 (unmatched IMHO with Flow Master 40s and turn downs).
The combination will satisfy my need for manual trans, full power shifts,noise,!power, ET, modest street ability, and the specialized home brew fuel consumption.
A year ago a single E85 station opened in Memphis. Prior it was a trip to Mississippi to get fuel. So E85 was out and that’s what drove me to E98 on “alcohol fuel plant permit”. Now- E85 will be a tuning step and next year my fuel making activities should be in full swing. Allowing careful migration to E98, at a buck a galllon.
I have some folks behind the plan- the worlds largest privately held company (a food company, nameless at this point, that is a client of mine) has tentatively committed to 10,000 lbs of free waste sugar for my use. That makes more azeotrope than one car can use. A big part of this Frankenstein project is raising awareness of alternative feedstock ethanol production, sorghum crops, “corn is bad”, and E98 racing fuel service. It’s a billboard I am trying to form. There are other entities tied to the vehicle, not financially, but that have fed me tech/data/support.
Anyone in a rural area below the salt line with an acre of property can raise and harvest sweet sorghum and produce azeotropic ethanol for fuel. It is my intention to both provide the distillation system, the legal/statutory path, the expertise on crop/fuel/process and offer a vehicle that proves hydros ethanol merit.
And dead hook at some point, pull a wheelie, stay in it and get it on video. So an altruistic path to wheelie glory without a Chevrolet being involved, a proper race car, and lots and lots of money.
I am not a tree hugger or a whale saver, on the contrary. But along the way I have figured out corn sucks, sweet sorghum is four times more awesome and if I could run every car on ethanol, affordable and practically- I would.
Ethanol part might fail- car will perform for sure.
Stabbing the engine for dry fit this month. God willing.
Pictures forthcoming - new thread started. See ya
The plan-
SFI balancer.
So FEAD- gone.
