Well, it’s been a while. As usual life gets in the way of playing with trucks and cars.
I did quite a bit on this, probably not pic worthy, but I’ll flood this post with them anyways.
Cleaned the old sealant out of the window gutters and applied new. Bought an Auxbeam multi switch panel from Amazon to run a bunch of accessories and lights. Had to make a pedestal on my floor plate to accommodate the bracket so it cleared the cup holders. Made up some brackets to mount the circuit breaker and the new power distribution box I added to run this unit and my box winch and probably even the front winch. Used 1/0 welding wire.
Added a couple ground blocks as well, 1 on each side of the engine bay, again connected to the battery and body with 2 AWG wire.
Scuffed the window trim and floor plate and got both in etch primer ready for paint. Fixed a couple small dents on the hood edge that I either failed to notice or consider worthy of repair back before scope creep took over. Can’t remember. Lol.
Got the underside of the hood all degreased and pressure washed, covered in etch primer. Got the holes cut in for the heat extraction style hood scoops. Going to 3M panel bond those on.
Also, because I failed to plan properly, I originally had blue rockers and everything else is green in the dash, so I wasted money and bought the green version instead and swapped them out. I’ll use the blue in the BII build.
But the best part is the sign my daughter made me while she was “helping” me in the shop today. She’s 11 and never even says this word.
Must have been hearing me say it a million times working on things. Kid cracks me up.
