1987 Ranger 4.0 SOHC
burner_123321
6
Florida
Hey. This is my first post here, but since I've bought my '87 Ranger off the side of the road 4 years ago, I've been using this awesome site. It's been a huge source of information for every project on my truck. So here's my truck's introduction
1987 Ford Ranger 2wd
8.8in 31 spline rear (with discs) from a 1997 explorer
3.27 gears with Trac-loc
4.0 SOHC v6 from a 2001 sport trac
I've been thinking of doing a write-up of my engine swap. There's not a lot of info on this swap, everybody seems to think that it's useless and that I should have swapped a V8. But if anybody might find it helpful, I'd love to do a write up on it.
5,332
Welcome to TRS :)
I am sure people would like to see a write up
The reason 4.0l SOHC wasn't as popular of a swap is because the 1990-1994 4.0l OHV was almost a plug and play swap in a 2.9l Ranger, 1986-1992
V8 swap is the same work/effort as the 4.0l SOHC swap, and you have a "V8 Ranger" when its done, V6 Rangers are everywhere, made from 1983 thru 2011
But a labor of love is always worth the effort
Ranger850
Banned... except Florida... and here soon
3,659
Tallahassee Florida
Stock 2"
Stock
But how many 1987 Rangers came with a 4.0?
A Ranger that old with a 2001 4.0 would probably just as sweet as a v8 swap, IMHO
burner_123321
6
Florida
It actually turned out to be pretty "easy", the fm132 bolts up with a 2001 ranger flywheel and clutch, the original clutch slave cylinder works. The engine-mounts from the 2.9 bolt to the 4.0 sohc and it slips in with some trimming to the evaporator box, and it leaves the trans in it's original mounting location. I didn't have to change the dash. The engine is controlled with a Speeduino, and that was arguably the hardest part. Because no one has a fuel map, timing map, AFR map, or even an after start enrichment map for a 4.0 sohc. If there is a way to upload the TunerStudio file I will, or at least post pictures of the maps i made.
snoranger
Forum Stuff Member
Forum Moderator
ASE Certified Tech
10,033
Jackson, NJ
'79,'94,'02,'20
All Fords
Uncle Gump
Forum Moderator
7,965
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Lead, Follow or get out of my way
I think it's a pretty cool swap. Seems several folks out on the west coast have went this route.
200 horse reliably all day long.
If you want to put a detailed how to article... Hopefully with pictures...I feel there could be a place for the information here on TRS.
5,332
Yes, the mechanics of the swap shouldn't be an issue, if starting with a 2.9l Ranger, same block patterns as the 4.0l OHV and 4.0l SOHC
Does the Speeduino use the Knock sensor, i.e. can you run 87octane gasoline?
Uncle Gump
Forum Moderator
7,965
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I had never heard of Speeduino... I had to look.
I went through the I/O list and don't remember seeing knock sensor specifically.
There were spare inputs though.
Ranger850
3,659
Tallahassee Florida
Stock 2"
Stock
