1987 Ford Ranger STX
LilGreenRanger87
Auburn, Wa. Currently in Kuna, Id.
2.9L V-6
Hey everyone. I have a 1987 Ranger STX and i am looking to lift it. The local 4x4 shop told me i couldnt get a lift bigger then 4 inches for it but i wanted to put a 6 on it. If anyone could help me out that would be great! Id like to not have to put it on myself because im really busy with work but i will if i have to.
djt
I dont know if youve already done the lift, but as far as buying a lift you'll only be able to get 4 more inches out of a 6 inch lift. The STXs have the highrider which is 2 inch lift from the factory and no manufacturers sell option specific lifts so just deduct 2 inches from the lift you buy and that'll be the lift you'll get. I found out the hard way and had to buy the 4 inch lift radius arm brackets and axle drop brackets just for a 2 inch coil spring spacer. Maybe you'll have an easier time than i did with mine.
kunar
131
Toledo, Ohio
5.8l
not all STX trucks had the (optional) highrider suspension. in fact most of the trucks DID NOT.
to the OP: you shouldnt have any trouble finding a 6 inch lift for the TTB, and if in fact you do have a highrider front end, it will only lift it about 4" over stock.
mp3deviant721
24
Eau Claire, WI
2.3l of fury
Theres tons of lifting options for the TTB trucks. Look in the Tech Library.
xkotyx
20
Waynesboro, VA
yeah do alittle research. youll be suprise at all the options.
Kirby N.
March Truck of The Month
