1987 Bronco 2 5-speed (2.9L) needs clutch ? Any hints/hacks/tips?
BTR
Northern California
Ford Bronco 2
Just trailered home ‘87 Bronco 2. I welcome any guidance on the coming clutch replacement. I haven’t really seen it yet, but hoped to be able to drop the trans and transfer case together: probably not, huh? Thanks for any time on this.
gaz
649
Wa, Bremerton 98310
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
BTR:
I've use 3 different brands of clutch with my 87 2.9l:
Zoom 2 Kevlar; very grippy, no fun in traffic but super strong clutch, nothing helped get power down better
Centerforce Stage1; better than stock, easier on the leg but did not get as much power to pavement
Some OEM; the cheapest, felt like stock, made my 2.9 feel like a 2.3 four banger but it worked well as far as shifting experience and service life
Also, all 3 were for the 2.9L; I have since learned that I can use the stronger, larger 4.0L clutch. When my current clutch dies I will be using a Centerforce stage1 4.0L replacement.
franklin2
1,750
Virginia
Taking the transfer case off separately sure makes it lighter and easier to handle.
And I had a ranger and Bronco II. I bought the Bronco II with a bad 5 speed. I swapped the 5 speed from the ranger into the Bronco II. I know some guys do it, don't know how though. But I could not get either one of those transmissions in or out without taking the y pipe off and dropping it down. So that can be another can of worms, getting the nuts loose on the exhaust manifolds. I was able to do it though, soaking them with penetrate, and using a impact to back up, go in, then back up and gently working them off without twisting the studs off.
snoranger
Professional money waster
ASE Certified Tech
13,621
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Don’t do it... take it to a mom and pop exhaust shop. Have them take the y pipe out and reinstall it. If the bolts/studs break, they’ll replace them.
BTR
Northern California
Ford Bronco 2
Thank you. I’ll hit those with Blaster solvent tonight and look for that.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
If you're going to do the 4.0 clutch swap, read up on it tin the tech section. Not worth putting a 2.9 clutch back in. Only hard part is getting the starter plate for it.
@85_Ranger4x4 has video somewhere of what happens to a 2.9 stock clutch when you start building up the engine....
BTR
Northern California
Ford Bronco 2
BTR
Northern California
Ford Bronco 2
Good to know. I’ll start investigating starter plate sourcing. Thanks.
17,767
SW Iowa
FWIW I don't know if a bigger clutch would have really helped much though.
