1986 2.9 flat tappet?
RangerGoolz
8
Colorado
I have looked online and found conflicting info but am I correct that my 1986 2.9 has a flat tappet cam and hydraulic lifters? I had been using mobile 1 10w40 and recently changed to Brad Penn simi-synthetic 10w40. I did this for the extra zinc in the Brad Penn. Any thoughts on this oil? Engine is in great shape at 115k miles and has a very slight leak at rear main which I plan on having fixed very soon.
Junk Collector
Truck of Month
4,800
Rapid City SD
You are correct about the cam and lifters.
Dunno what to suggest for oil. The extra zinc for sure will not be a bad thing! Just spendy. I have read that zinc additives don't do much because they don't fully blend with the oil so if that's true, your plan of attack makes more sense.
I have just always run whatever is cheap in my engines, except my V10 (that gets full synthetic 5w20.) No premature failures yet. I know PJ had some issues with a cam coming apart on his 2.9 and blamed it on low zinc Mobil 1. He knows his engines really well and that could very well be true but I would like to see some sort of scientific analysis that proves that the oil caused the problem... and not contaminants from something else or just a straight up worn out engine.
