1985 bronco II clutch replacement
Erebus1985
Washington
Ford bronco II
2.8 V6
So just pulled the drive shafts, transfer case and tranny, and found out not only was I missing a few bolts on the tranny but the whole pilot bearing was missing LMAO. Anyone ever have this happen with a used buy?
sheep herder
1,024
sheep pen
If it ain't broke, break it.
There is no such thing as a 1995 Bronco II.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,581
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Used, private sale buys from someone you don't know, often have hidden crap the previous owner screwed up and are looking to dump on someone else.
I also fixed the title of your thread for you.
Erebus1985
Washington
Ford bronco II
2.8 V6
Thanks for the title fix, I've noticed this with most of my buys. Always learning that's the important part haha
Eddo Rogue
2,501
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
broncc
Ham Radio Operator
564
MA, USA
Ford Bronco II
5"
Giving my truck more money than it deserves.
Yes I have unfortunately. One of the bolts for my starter was over tightened and stripped out. I had helicoiled it and thought I was in the clear. Wrong! I ended up having to drill clear through the transmission after the helicoil failed.1231201717_HDR.jpg
Eddo Rogue
2,501
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
its very rare a heli coil actually works, at least for me.
Erebus1985
Washington
Ford bronco II
2.8 V6
Have some issues, I busted the O-ring that connects the clutch to the tranny. Any ideas on the size or where I could find a replacement. Went to ford and they said the part was obsolete. Can't find anything on LMC
Eddo Rogue
2,501
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
If you can probably order one based on dimensions. I have a found a few non specific, but fitting o rings and bearings searching measurements
MikeG
752
central Texas
B4000
2"
235/75r15
What did you break, exactly? One of the seals in the hydraulic clutch hose system? On which end?
Worst case take pieces of old o-ring down to parts store and buy several that are the closest to the remnants.
Erebus1985
Washington
Ford bronco II
2.8 V6
Broke the O ring for the hydraulic clutch line that leads into the transmission. Sorry for the late response I never got a notification
Erebus1985
Washington
Ford bronco II
2.8 V6
I'm not shur where the broken O-ring went, it was a long night.
