cyclejohn
- Aug 29, 2021
- 11
- Reidsville, NC
- Ford Bronco II
- Engine Type
- 2.8 V6
- 2WD / 4WD
- 4WD
I used the search feature on the forum to try and find the answer to my question, and to not bother anyone on the forum, but, after reading through pages of threads and post I still haven't found an answer to my question.
So here goes: The 1984 Bronco II that I bought about a month ago started running hot (actually blowing coolant and steam out the rad cap into the coolant reservoir) within 6 or 7 miles of the place where I bought it. The radiator and reservoir both had the correct level prior to driving away. I told my daughter to just park it and get in the car with me and we would go home and I would send a tow to pick it up. I just hate that I drove 100 miles to buy it.
Anyway, picked up and delivered to my house the next day. My daughter explained to me how the B II felt during the few miles that it actually drove. I am finding so many mechanical problems that weren't visually apparent when I checked it out the day prior to purchase. No big deal because I can fix what I have found by robbing parts off of the '84 Bronco II that my daughter totaled in a wreck back in December.
In going through the cooling system to verify good flow and no blockages, I removed the lower radiator hose mount housing on the lower left side of water pump, and it had a 205° thermostat in it, verified it was opening in a pot of water with a temp reading probe in the water. Started opening at 205 and was fully open at 215.
The upper radiator hose mount housing attached to the front top of the intake manifold had a 180° thermostat in it. Verified by the temp probe and pot of water. Starts opening at 180 and fully open by 190°.
My question: In all of the threads and post I have read here, I have never seen the word 'dual thermostats', '2 thermostats', or 'thermostats', only the singular use of the word thermostat. The '84 that I am robbing parts off of had a single 180° thermostat in the bottom radiator hose mount housing and the temps on it always ran exactly where it needed to be.
Is it OK to just run one thermostat in one of the hose housings??? If yes, which one would be the better location to do it???
Thanks for any insight into this.,
John
John
