ExploreNW
- Mar 12, 2019
- 131
- Mead, WA
- Ford Ranger
- Engine Type
- 2.3 (4 Cylinder)
- Tire Size
- 235/75/15
Do you have access to scrap sheet metal? If you have a Dremel, drill, wire brush, and a fine tooth saw you could make an adapter in an afternoon. The factory used 5200s/ 32/36 Webers on the 2.3s. The intakes for these are a weird oblong shape. The filter inside is wide enough that I think you could cut and fit something, but the factory cleaners for those took square filters. If you have a welder or access to one it would be an easy job for you. Beware using plumbing fittings though. Seen some rednecked stuff in my day. PVC & ABS melt in gasoline and snot up your manifolds real quick.
