180° thermostat in 2.9l v6
180° thermostat or 192°
  • Total voters
    8
stamina
34
Wilmington, NC
4” suspension
265/75/r16
built her in a storage unit
i saw in the description/upgrade list of the 2.9l v6 forum it said install 180° thermostat, is this a good thing to do or should i stick with a 192° thermo?
fastpakr
2,832
Roanoke, VA
Stick with 192.
sgtsandman
Aircraft Fuel Tank Diver
12,637
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Stick with the 192.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
stamina
34
Wilmington, NC
4” suspension
265/75/r16
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
The 2.9 is pretty much what it is with the stock processor.
And they really do thier job well.
If you upgrade to mega squirt and some gm sensors, then hci and porting ...deck the heads and block...maybe some pistons might be worth the effort.
Anything with a tunnel ram on it from the factory has to be good.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
192.
Get a hi flow if you want. I like mine, but I also have a tiny assed rad and tons of fans for moar coolings. Setup works well.
Stock 8DT brain box doesn't like the 180 thermostat. Dumps fuel to it constantly.
No, it doesn't make it more gofasts.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
You could go fancy assed like I did and do the dual snorkel Euro plenum.
But listen to Bobby. They're impressive with a megasquirt. Respond well to methanol as well.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Motorcraft filter. Best ones.
Gauge is up to you.
I vote no on a capillary tube one. Great way to get an unexpected "total loss" oiling system.
Summit makes a decent electronic one.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Psi gauge won't leak much...just tee it into the stock location
stamina
34
Wilmington, NC
4” suspension
265/75/r16
Gauge is up to you.
so i shouldn’t get a mechanical one from the autozone ? they’re like 20 bucks
stamina
34
Wilmington, NC
4” suspension
265/75/r16
i’ve got some thread sealant, if i goo it up real good it should be good i think
