09fx4guy
- Jan 10, 2010
- 176
- USA
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0
- 2WD / 4WD
- 4WD
- Total Lift
- Pre Key w/ #1 Bars
- Tire Size
- 265/70R16
If I may, I will describe what I did with my truck which helped soften the ride. When I cranked up the factory bars, the ride was really harsh.
If you wanted to, you can easily replace the torsion bars with a set of new ones that are a little "firmer". There are three levels of bars, #1, b, and f, with #1 being the firmest and f being the weakest. I used the #1 bars not cranked up too far. My factory bars were b, and had some mileage on them. You can get brand new oem bars from Tasca parts for less than $100 each. I also used the pre 2008 torsion keys, which you already should have.
Then, I purchased a set of Rancho shocks (5000x), with the extended length shocks for the front to allow more down travel.
I was quite satisfied with the end result for the front suspension, potholes are not too bad. (And I live in NJ, where potholes have their own zip code.)
I actually have the factory leaf packs on the rear with the 2.5 inch blocks from an earlier Ranger. You may have to replace the leaf packs in your truck to a stock style, or at least ditch the add a leaf. Rancho shocks in the rear as well.
The ride height is decent and fits 31 inch tires real nice.
