10" Drum Brakes Wheel Cylinder Link Pins?
Basilius
USA
Ford Ranger XLT
2.5 (4 Cylinder)
2.5L
What is the part number for the the 10" rear drum brakes wheel cylinder link pins (forked pins that stick out of the sides of the wheel cylinders)? I need to replace them and I can't find the part number. It looks similar to this:
Rock Auto 5% Discount Code: F9A1A579ACFAD1: October 1st, 2021
55trucker
60
Oshawa, Ontario
It is referred to as a parking brake strut, you'll find one at Rockauto under your vehicle listing.
ericbphoto
Overlander in development
Forum Moderator
5,939
Wellford, SC
6"
I thought he was asking about the little pins that extend from the ends of the cylinder.
55trucker
60
Oshawa, Ontario
oooops, my bad, clean off the coke bottle lenses here & yep.......dealer item only?
Uncle Gump
Forum Moderator
4,872
Plano IL
Lead, Follow or get out of my way
Basilius
USA
Ford Ranger XLT
2.5 (4 Cylinder)
2.5L
Uncle Gump
Forum Moderator
4,872
Plano IL
Your link takes me to a bleeder screw.
ericbphoto
Forum Moderator
5,939
Wellford, SC
6"
You clicked it wrong. It takes me to some pins at Advance. But I there's just a useless Wearever part number that I haven't cross-referenced yet.
Basilius
USA
Ford Ranger XLT
2.5 (4 Cylinder)
2.5L
It should be Wearever Drum Brake Wheel Cylinder Link Pin (part #1414-2A). A reviewer says that it works with 1968 Mustang 10" rear drum brakes, but I don't know if those are similar to Ranger 10" drum brakes.
pjtoledo
869
Toledo Ohio
Fords
3.0 2.3
get outta my way, I'm falling!
the Q & A at Advance says it does not fit a 2004 Ranger with 10" brakes.
so we still don't know for sure.
