- May 14, 2018
- 1,037
- Western Mass.
- Ford/Ranger XLT
- Engine Type
- 3.0 V6
- 2WD / 4WD
- 2WD
- Tire Size
- 225/70/R15
- My credo
- If it's not broken Don't Fix It!
For the 9" drums the part numbers are the same but I'm not sure about the 10", I would imagine, guessing here, that they would also be the same.now that it is mentioned, the only difference between a left and right is the hole for the Ebrake cable.
both parts are stamped identically, the each have both L & R bosses, only difference is 1 is drilled left, other is drilled right.
correct???
also for 2007 both plates are still listed. are 2002 & 2007 compatible?
Where did you get your listing for the backing plates @pjtoledo so I can check it out?
I already spent this much time I'm invested now...
