1 step closer for V8 swap
svtcards
137
Lyman maine
302
3'' front 4''back
Just finished painting and detailimg engine bay.now need to push this thing out and drive mustang in and start pulling that motor out.hopefully all put in b4 snow fall
svtcards
137
Lyman maine
302
3'' front 4''back
svtcards
137
Lyman maine
302
3'' front 4''back
Not sure y I'm having a hard time uploading pics not sure
svtcards
137
Lyman maine
302
3'' front 4''back
svtcards
137
Lyman maine
302
3'' front 4''back
1 thing I did notice though is the coolant tubes from the engine that connect to the heater core are right next to heater box to the point that I won't be able to connect any hoses.am i supposed to cut them back to fit or should I adjust engine more in engine compartment to try to compensate for this? haven't really found any threads on here that people had this issue on the 80s rangers.
85_Ranger4x4
17,808
SW Iowa
What tubes are you using?
I tried using one from my crown vic engine and it was no dice, they go back and hit the firewall before they are close to sitting on the studs. I have heard Explorer 5.0 ones fit the best but I haven't had the ambition to drag them out of an Explorer yet to try and haven't came across a car where someone has done it for me. :dntknw:
svtcards
137
Lyman maine
302
3'' front 4''back
So what did u end up using? Or did u end up bypassing heater core until u find something that works?
svtcards
137
Lyman maine
302
3'' front 4''back
I'm using the factory sn95 ones.didn t know this was an issue until I dropped engine in
svtcards
137
Lyman maine
302
3'' front 4''back
svtcards
137
Lyman maine
302
3'' front 4''back
I was thinking of cutting them back and reflairing but wasn't sure if that was possible or if someones already did something similar to that already?
85_Ranger4x4
17,808
SW Iowa
You wouldn't be out much, the explorer ones kick up at 90 degrees.
I just used regular heater hose, the tubes are on my to-do list but they are a ways down from the top.
svtcards
137
Lyman maine
302
3'' front 4''back
So u connected one hose directly to the water pump on one side and where on the on the other?since sensor is thread to the tube and intake?and your saying explorer tube may still not work for me?
sjmills1
Law Enforcement
Alabama
Ford RAnger
2.5 (4 Cylinder)
sjmills1
Law Enforcement
Alabama
Ford RAnger
2.5 (4 Cylinder)
SVT - Thank you so much for sharing your efforts on this for us Newbs!! I am just starting my V8 swap and your picture showing the fitment of the Serp belt system in the engine bay of your Ranger confirms that this arrangement will fit in my 1991 Ranger V8 Swap project. Please keep taking pictures and update us with the progress of your build.
Thanks!!
