88workcar
- Apr 29, 2019
- 48
- Pierre Part La.
- Ranger XL
I finished porting my heads and intake and put the motor together. Initial start up was hard and truck shakes from apparent dead cylinders. I did find two different injector clips that didn't go on correctly and 5 of them that would not stay down due to broken clips. I fixed all of that (tyrap over injector clip) and it made a big improvement. I now only have #1 cylinder that is not running. I have verified voltage to the injector. I can feel the injector pulse while engine is running. I also verified the valves are opening and closing. I removed the injector and bench tested it. (good) They are all new FORD injectors.
I removed the plug and set it on the intake and looked for spark. It is yellow, doesn't look healthy. So I swapped the plug wire with another, same results. I tried a fresh plug, same results. I put that all back as it goes and pulled #2. This one has a better "looking" spark to it. My plugs and wires are 6mos old, the coil pk is an auto parts place "BLUE" pk, an upgrade from el-cheapO. It is 2 months old. Can it be that the coil is too weak to work correctly? I did also swap all of the wires from one side of the coil to the other and the problem remains as is. And last, I have a strong unburn gas smell at each startup. Thanks for any assistance.
