- Sep 13, 2020
- 55
- Texas
- Ranger FX4 LVL2
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 4WD
- Total Lift
- 2 inches in the back, not enough in the front
- Tire Size
- 32x11.5x15
It's been a long winter down here in the banana belt in Texas.....
I've been relying on the Yellow Sub now for about 10 months, and so far not much surprises. The inside of the front tires have been wearing out and it is becoming an issue. Ball joints? Has a couple of degrees of negative camber. Looking at a new set of tires, however I don't want them to get eaten up. Guess I'll have to stop by my local alignment shop and consult further. I did fix that pesky oil leak up front. Thought it was something else, turns it was the oil (idiot light sender) sensor leaking like crazy. Got that R&R'd but I did find some alarming when I was down there. A wire harness that had rubbed it's self all but through the wires. Simply from vibration. Located right next to the oil sender on my 4.0L dog motor. So have a look 'yall. I repaired the harness using sone 3/4" heavy wall hose split duwn the side and wrapped the heck out of it with some of that cheap chinese electrical tape. I'm realizing that all the 4wd rotating assemblies will need some going through. The previous owner had just replaced the forward drive shaft saying that the vibration was the clue that it needed to go. I wonder if he got it aligned correctly. There must be some procudure to use a mag base dial indicator, and turn it by hand. Nothing is leaking so far. Just thing that the tires are the culprit with the road vibrations. Even with a new balance. With 140kmi, it's no wonder. Thinking a new set of 31's will remove the "bad tire" sound. Cheapo chinese junk tires is what it came with up front. The coilover conversion may have to wait, but I did get a Hobart Mig welder. Did find some shock towers, and will keep studying on what I need to do staying away from the "you know what you should of done" thoughts & feelings. Shock hoops? Hey why not! I should find the local group of off roaders.
Got the fan speed resistor & cable replaced after I realized one day that it was ether too hot or too cold inside. The interior has been at a stand still while I am still recovering from 4 shoulder procedures. But I have been getting used to all the extra organization area, which I require inside the center console. I needs me some "sole", console you know.
I did go to town in 4wd high the other day. Road was 100% packed snow. 12 degrees outside. Loved it! - Doug
