Purrfect312
- Dec 23, 2020
- 0
- 92253
- Ford Ranger
I have a 2007 Ford Ranger and about 6 months to a year the check engine light came on and it displayed PO304 which from the research I did, means that cylinder 4 is misfiring. I went through all the possibilities and did the following:
-Replaced all spark plugs
-Fixed all air leaks that could find, used brake cleaner to see if any revving happened when I sprayed it
-Changed out all coil pack wiring
- replaced camshaft sensor
-replaced crankshaft sensor
- replaced coil pack
-Replaced fuel injector
I also have my RPM needle jumping when the car is in idle. I need help! Any suggestions?
