05 Mustang 4.0 start issue
buell-eyed-devil
21
Wesley Chapel,Florida
FORD
5.0-ZF in process
3"body on new poly body mounts
Hey ya'll, watch this
Car worked fine till the other day it wouldn’t start. Corrosion on positive terminal pretty bad so I cleaned it, jumped it off and drove it home. Worked fine for a couple days then does it again. Battery was low so I changed it to one with 800 cc’s. Now sometimes it cranks fine and sometimes it acts like the battery is dead. Radio loses stations, no click from starter. Any ideas?
buell-eyed-devil
21
FORD
5.0-ZF in process
I turned key to on and left it for several minutes to reset alarm. Working now but I have my doubts
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
If there was bad enough corrosion on the battery terminal, it's likely the same corrosion is on the other side.
buell-eyed-devil
21
FORD
5.0-ZF in process
Problem is back. Load tested battery at almost 800cca. nothing. no codes. no nothing. Car was in a bad wreck before I got it. Seems anti theft is culprit but I dont know what to do with it. Any ideas would be appreciated
rubydist
855
Denver
Ford Ranger FX4
The pats sensor surrounding the ignition lock is a fairly fragile device, and they have been known to be damaged by a hard shock like a significant accident. If it is giving you the signal that it is not reading the key chip, I would consider replacing that sensor.
buell-eyed-devil
21
FORD
5.0-ZF in process
Nothing comes up on scanner. When you turn to start everything dies
buell-eyed-devil
21
FORD
5.0-ZF in process
Something just occurred to me. The previous owner (the crasher) broke a key off in drivers door lock. To deactivate anti theft you have to unlock drivers door with a key. I wonder if this is my issue.
buell-eyed-devil
21
FORD
5.0-ZF in process
No ideas huh?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
PATS security codes wont show up on a scanner. You have to put the key in the ignition, turn to run, and watch the anti theft light. After a minute if there is an issue it will start to flash a sequence, the sequence is the code.
buell-eyed-devil
21
FORD
5.0-ZF in process
ordered a new key barrel for door. they sent me ignition set with dongle. is key set the same? Dont think door uses a chip
buell-eyed-devil
21
FORD
5.0-ZF in process
When I turn key to on there is no anti theft anything blinking. Maybe pats sensor?
buell-eyed-devil
21
FORD
5.0-ZF in process
Car never stalled out. When it runs it runs fine. Since I towed it home nothing. Also taillights all didnt light up
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Did you ever actually check your ground cable and ground straps? Meaning on the block side, as well as testing for internal corrosion.
buell-eyed-devil
21
FORD
5.0-ZF in process
Yes. Here's a new one. Got in Today and hit key. No start so I held it. 10 seconds later it starts but locked in park. Also right rear lights 2 of 3 don't work but bulbs are good. Car is haunted
buell-eyed-devil
21
FORD
5.0-ZF in process
Thinking about trading for a Kia
