03 Supercab - Camper Build?
dustyrangers
57
Colorado
Ranger 4.0 4WD
I have a 4.0 Ranger with about 210k miles that’s been lifted and off-roaded for the last 50k miles or so. Looking to do a camper build that is reliable enough for the occasional long haul and I like to take things a step at a time so took the bed off today and started to clear the engine bay to look at the top end. Not as bad as I was expecting after a breaker bar and two broken/rusted bolts, slid right out with the help of some 2x4s. I’ll be gutting the interior soon as well.
I have a lot a of ideas for what to do but looking to hear yours. My challenge in short is to have a reliable camper truck for Colorado area mountains that can haul things in whatever is left of some type of bed and sleep 2 adults, a baby, and a dog. I have a bed and camper shell for sale now, too.
56320
56321
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Uncle Gump
Token Old Guy
13,442
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Grind the rivet heads.... remove the brackets... grid remaining rivet flush to the frame.... air chisel with a punch bit to punch rivets through frame.
dustyrangers
57
Colorado
Ranger 4.0 4WD
Do you replace with stock parts or worth upgrading? Maybe not worth it where you are either way.
Uncle Gump
Token Old Guy
13,442
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I got 13 years out of the factory brackets and shackles...
I replaced them with Doorman hangers and shackles.
JohnnyO
Moderator Emeritus
Forum Staff - Retired
2,840
Pittsburgh, PA
2.3 EcoBoost
1.5"
"220, 221, whatever it takes."
There are several Ranger and other small truck camper builds on YouTube. I like this one, it's the new Ranger and a regular cab longbed that we don't get in this country any more but it's a good setup.
JohnnyO
Moderator Emeritus
2,840
Pittsburgh, PA
2.3 EcoBoost
1.5"
dustyrangers
57
Colorado
Ranger 4.0 4WD
I have the fiberglass camper shell in the picture in pieces and I’m not sure if I’m going to use it. I’m considering a pass through from the cab to the rear (any idea if this wall is structural?) and would ideally still have some kind of a flat bed in the back big enough for a 4-wheeler. I have a winch I’m planning to put somewhere and can use this to help load.
Thinking I might go full prepper and add fresh water tank and a bigger gas tank. Already have solar, inverter, and some deep cycle batteries (including my truck battery). Will strip most weight and things that aren’t needed.
Running a list for parts and have the 722-100 brackets and hangers for $40 a side.
Gutted the interior today except the dash. Any tips on this one? Never done anything with an airbag and seems like that could go wrong quickly.
56376
dustyrangers
57
Colorado
Ranger 4.0 4WD
My first vehicle was a (white) 94 regular cab long bed that I was just reminiscing about. 2wd 4-banger and very intentional decision on my dad's part. I wish I kept it for a 5.0 drag swap.
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
You don't use a deep cycle as the battery for your starter do you? I'm no expert on battery chemistry but ive read quite a bit saying that thats a no-no.
dustyrangers
57
Colorado
Ranger 4.0 4WD
Optima Yellowtop. Not something I generally run my solar on but apparently it could handle it. It's made to run until dead for camping or cars that sit a lot without a trickle. I have 2 other deep cycle lead acid batteries that would be the primary for the solar.
dustyrangers
57
Colorado
Ranger 4.0 4WD
Dash all the way out and interior pressure washed. Moving back to the engine bay.
Planning for bigger alternator and tranny rebuild. I redid all the cooling, front diff, and fluids last summer. Dropping tranny soon for a rebuild. Anything else I should plan for to make sure it keeps on trucking? Gearing, driveshaft, etc? I’m sure I’m wrong (I hope I’m wrong) but I feel like I could easily bend this drive shaft in half.
56404
dustyrangers
57
Colorado
Ranger 4.0 4WD
Bay close to the point I can get the intake manifold off followed by the valve covers. Distributor thing is off and I also replaced this last year and the wires. Planning to do typical sensors finally once everything is out. Whole front end was already recently rebuilt too including the diff which is the one I did last year.
56405
