'03 Ranger 2.3L Single Cab Manual W/7.5" 3.73 Rear Axel Backlash?
Zunaro
Texas
See Ford specifications
Stockola
Worn Bushings
Treads about 1/2 to replace-o-time
Manual everything - Gearbox to Windowcranks
So, I have 20 thousandths at my wheel hub when I push (pressure towards locking pin) and pull (pressure away from locking pin.) However, when I try to pull the wheel hub in any other direction (up/down/left/right/diagonally) I get zero play whatsoever.
Is this normal? I checked this same test on my Dad's Tacoma and it was solid in any direction, but I have no idea if this is even relevant. I just replaced the spider gears and locking pin because my spiders were worn pretty welll with some pitting and some minor chips. When I had the axels out I looked at them and didn't see anything alarming there, but also not sure what I am looking at on them. Ring and pinion checked out at 13 thousandths, and also were not damaged cracked pitted or anything like that, looked great actually.
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
Welcome to TRS
A small amount of end play is normal for C-clip type axles (the Tacoma isn't C-clip). 0.02" is nothing.
You may be able to reduce it by using thicker thrust washers behind the side gears (non-limited-slip differentials), but it doesn't hurt anything.
Originally Ford put O-rings in the C-clip grooves to help act as a cushion to take up the play, but with as old as these axles are getting, the O-rings often aren't present anymore (IIRC the O-ring went on the side of the c-clip next to the cross shaft).
Now if it was more like 0.2", then you might have an issue (usually it's the clutches are worn if it is a limited-slip diff).
