02 4.0 soho random surges
Ohhnulix
6
Dade city
Ford ranger
My 02 4.0 was broke down for awhile, finally got it back up and running, but sometimes I get these random surges. It’s worse while idol but happens while driving too, when it’s i doling the whole truck shakes and the engines acts like it wants to stall, when you’re driving you can feel it die down, then rev back up and Learch forward, then die down again. I’ll fo that for a few solid seconds then stop. I’ve been told it sounds like water in the fuel, would I be correct to guess that? I’ve tried heat but that doesn’t seem to make a difference
8,370
How long is awhile?
Gasoline lasts 4 to 6 months in a vehicle's gas tank unless its filled to the top so no contact with air
Check/replace PCV Valve, and give its hose a close inspection, it likes to crack on the bottom of the elbows
Clean MAF sensor, every year on the 4.0l's
Clean IAC Valve
Both are easy to do
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
Some people swear by, some swear at SeaFoam; have never used it myself;
I just do a Premium Fillup plus bottle of InjectorCleaner once\twice a year.
FuelFilter & Plugs+Wires & OxSensors & TimingTensioners all need changing at least every 100kMiles?
Does sound like a VacuumLeak somewhere. Any OBD2 TroubleCodes?
Ohhnulix
6
Dade city
Ford ranger
How long is awhile?
Clean IAC Valve
Both are easy to do
i get a “bank 2 rich” and a “bank 2 lean” code (it switches, sometimes it’ll say one, other times another, I think the o2 sensor is messed up, I’m changing that when I get the chance, I do think I have a vacuum leak, as my AC doesn’t change off of defrost, I’ve checked the vacuum res (the little black ball thing that always breaks) and the vacuum line going into that seems to be the only one getting good suction, but I’ve taken that off and put my finger over the line to see if it helps the suction on other lines and it stays about the same, so I think the lines somehow split? I don’t know , the ball looks fine and doesn’t seem to have any leaks, any way to test that? I have yet to find any other hoses or spots that seem to have issues
