Not much new with the truck. Core support finally gave up the ghost. Not sure if I want to build one or buy a replacement.
I did pick up another 4.0 for it. At 285,000, the engine in the truck now is showing its miles. Visibly burning oil and the valve train clatters pretty bad when it’s cold.
Just under 150,000 on this one.
I picked up an old Meyer ST 7.5 snow plow for it as well.
The plow was rough but for $100, I can work with it.
Proceeded to cut the mold board off and narrow the blade to 6.5 feet wide.
The outer most ribs were rotted through and pretty thin overall so I had some new pieces cut from 5/16” plate.
While I was waiting on some 13ga. cold rolled to come in for the new mold board, I got started on the truck side mount. Had to cut out the goofy crossmember in front because I wanted to use pre existing frame holes.
When I started measuring everything, I noticed the front of the truck looks like it’s leaning to one side even though the frame measurements indicate it leans the opposite direction exactly one inch (Ranger lean). That’s when I realized my core support is roached.
Rubber body mounts are finally shot also.
Anyways, got the plow mount done.
It’s a little too high but I’m not willing to let it hang way down. I’m going to modify the push frame to compensate. I need to make up approximately 6 inches to get the plow close to where it needs to be.
More on that later. It’s next on the list.
Rebuilt the pump in the meantime as well. Had to re-solder the wires back on a couple coils but everything functions. New decals even.
