Quick update.
Finally got the correct driveshaft in the truck. Got rid of some minor vibrations and the noises associated with them.
Also did some spring work while I was back there. I had to reset the pinion angle so everything was apart anyways.
Removed the overload, and added the Icon add-a-leaf from my buddies Tacoma. I wanted to put Chevy leafs in but to do that, the bed needs to come off and I have unfinished projects inside the house that will most certainly put me in the dog house if they’re ignored.
Flexed it out as much as my stump will allow. The extra springs helped tremendously in forcing the front to work a little more.
And ordered 4 of these
I set the truck up to run the same shock on all 4 corners. A stock length 4x4 Ranger rear shock.
Had to clearance the lower tabs on the front a little bit so they wouldn’t contact the shock body.
Holy cow did the shocks make a huge difference in how the truck handles. It actually feels connected to the road and feels solid vs. bouncing around and swaying uncontrollably. I took it down a washboard gravel road and it soaked up the bumps instead of bouncing over them and tossing the truck sideways. By far my favorite “mod” yet.
