Brendan
- Aug 15, 2020
- 0
- Austin, TX
- Ford Ranger
Hey y’all,
My truck decided to pull a no crank, no start on me yesterday. No prior issues with starting. Battery reads 12.6V, pulled the starter today and took it to autozone to have it tested... all good there. I bought a starter relay and replaced my old one in the power distribution box, nothing. I’ve gone through all fuses and none are cooked. Cleaned battery terminals and neg/pos cable attachments. Have not thoroughly checked the cables that run from battery to starter but I dont suspect they are the culprit.
When I depress the clutch, turn the key to start, all I hear is the starter clicking and some small clicking from passenger side fuse box. All instrument panel lights come on when in accessory and then the airbag light flickers rapidly when trying to start. 6 months ago, I had the passenger side airbag replaced under recall at the dealer but no problems since then. My OBD-2 code reader tells me no DTCs are stored in the PCM at this time.
Any thoughts? Thanks in advance!
-Brendan
-Brendan
