Look at the 94-97 5.0's from pickups and vans. These are the same long block as the 94-95 HO motors, except for the slightly smaller F4TE roller cam, which was also used in the 96-2001 Explorer/Mountaineer 5.0. The F4TE cam specs like this: 256/266* advertised duration with a .422/.445 lift. Use it with 1.7 Cobra rockers and the lift goes up to .445/.473. LSA is 116 The HO cam specs are 276/266 (or 276/276, depending on where you find the specs) with a lift of .445/.445 and an LSA of 115.5. You should have no problem finding a pickup/van 5.0. Nothing wrong with carbing these motors, carbs work extremely well with the F4TE cam, best I've ever had a carb run in fact.
