donfordguy
- Jan 24, 2011
with bigger brakes and stronger trans but still ranger size
Ive seen really small toyota trucks from the 80s that had a dually rear. One was a camper another was s a box truck lol
Hate to break it to you, but those dually 'Yotas did not have a true dually rear. They had a single rear wheel axle that had a dually kit on it. Those axles will actually break sooner than our 7.5 rear ends because of the way the weight levers against the outer wheels.
i seen floater axles, but they werent 14 bolts.
a one ton 4X4 ranger like this guy is describing would weigh at least 5400 pounds. likely a lil more. but would need some huge ass mirrors to tow what it was SAFELY CAPABLE OF. at least 10 k with brakes just like a 150.
1 ton capacity and 30 mpg unladen. sounds like a good idea to me.
yup and they should put that 4.4L powerstroke in it.
10K is doable on a current truck with gears and trailer brakes IMO
yes it is.
but not regularly unless you like fixing transmissions.
the 4.4 is pretty neat. another well intended and fully worked out project, ignorantly collecting dust on the states side of the market, at the blue oval...
bastardz.
if the rotten bastards would package it for here it would be great. i would have rather installed that over the 6.5 in my truck, but only if i could prototype/experimental one out of there for testing.
i have not kept up with it since 08.
and i dont really want an electronic diesel, and it looks like you can use the old school mechanical stuff on this version either so fawk it for a retrofit.
i am ok with my little detroit for now.
i find the 4bt repulsive for daily driving. directly compared theres nothing smooth about them. pretty loud also directly compared. its almost ridiculous.
i cant find one cheap either that dont need work. they get better mpg for sure so i would like to have one in the garage if fuel gets too outrageous.....ratty or not, 5-10 mpg more will see me happily wearing earplugs holding on to a buzzy steering wheel at 6 bux a gallon....
but the db2 on the 6.5 has been eating all the shit i been throwing at it for years, so i cant complain at all.
the 4l80 may be an archaic dinosaur compared to the 5r55, but 10 k wont hurt it![]()
