Im looking around to find an electric fan kit to replace the mech. fan. Would i be better off with dual smaller fans or one big one? Also what size fan would be the minimum to sufficiently cool? Ive seen from 7 inch all the way to 18. thanks.
I don't think the point of the change is to improve the level of cooling but reduce the amount of power being used from the engine to drive the fan... hopefully a change to electric fan would increase available power and improve gas mileage while maintaining the same level of cooling.CM my advice is to stay where you are.. You have a tried and proven cooling system that doesn't NEED anything cone to it.. Ya can't do ANY better than the system you have now.. cool is cool!
Big JIm
Just about every vehicle that's manufactured today comes with an electric radiator fan, and they're so unreliable that the roadsides are just littered with vehicles who's e-fans have failed.....and e-fans will be much less reliable than the OEM mechanical fan/clutch assembly.
Other than being noticeably quieter, and potentially easier on water pump bearings, and giving a small but noticeable increase in power (especially under acceleration), and giving better fuel mileage*, and it being fun to tinker with and modify our Rangers, there is no advantage to running an e-fan.
*FYI, a mechanical fan with a clutch always turns at least somewhat, and it takes energy to turn the fan, so common sense would tell you that fuel mileage will be at least a little bit better with an e-fan. And real-world experience with e-fans backs that up. Speaking of which, do you have actual real world experience with running an electric fan on your Ranger? Or are you just theorizing?
