fuses!!!!
Tpenner93
does anyone one have a pic of the fuse block diagram for a 93 ranger 4x4 4.0 auto? The lights for my dash just went out and wanna check all fuses, but my truck does not have the cover for the fuse block, thanks for now
Just check it with a test light...that'll tell you which one is burnt out.
Important. If it a 5amp. dont go higher amps . fuzes, they blow for a reason.usually
if you go higher amps and you have a problem you can fry your dash circuit board...
IVE made a lot money because of wrong fuse.
Do you possibly mean that you've wasted alot of money because of the wrong fuses?
Just wondering...
Oh, to Tpenner93, I totally agree with Turboranger2.3 about the fuses. I put a 25 amp fuse in a 15 amp slot one day and it fried all of the wires in my dash.
That... was not a good weekend. I spend both days going through my entire dash, replacing and splicing the wires that had burnt and almost caused my car to go up in flames.
No, I think he means made. I get the impression that Turbo is a professional tech and that English is his second language.
And I will attest that as a professional, you can make a LOT of money if someone puts the wrong sized fuse in the slot. Burn up wires, modules, blow out bulbs. It's not pretty.
The fuse box cover won't help you, it just has numbers on. You need the drivers handbook.
Yes, is the answer.
Send me a PM with your e-mail address and I will get those right out to you, straight from the 93 EVTM.
Be sure your Inbox can accept quite a few Meg in attachments.
Check #11 and 13 in the cab.
Adsmo8 , nailed it , thanks
THAT SO FUNNY, STUPID MONKEY, CAN FIX CARS , BUT CANT READ AND RIGHT. ( FIRST LANGUAGE) I'II GET BETTER. I'M STILL LAUGHTING AT MY SELF.(THANKS ADSM08)
Haha, the first thing that came to my mind when I re-read all of this is that we (on TRS.com) all possess the ability to make conversation and correction without getting heated about it.
Adsm08, thanks for being so damned smart.
Oh, and turboranger2.3, at least you're not writing like this: u guyz hlped me ot SOOO much. sry bout the bad enlgsih!!11 LOL!
(Ugh... That took me too long to write, even with as short as it is.)
Penner, make sure you pull the cluster out and check for blown bulbs. I spent a week popping fuses before I gave up once and then drove around for a month without dash lights because of a blown bulbs.
I will check the fuse and then before i replace fuse will open it up and take a look at bulbs, but i dont know if it will be bulbs seeing as the lights for instrument cluster and my heater controls both are out. seems more like a power problem? but i dunno wont know till ya open it up right
That bugs the ever-livin' shit outta me. Seriously, people. Stop it.
i have the same truck and here is the pic.
fuses!!!!
