thesmokey1
How to set timing on 95 Ranger 2.3L? HELP!
My vehicle is a 1995 Ford Ranger XL 2WD with a 2.3l SOHC engine. I just got a great deal on this truck but the guy I bought it off of changed the timing pulley ( I think that's what it's called) on it and said that he wasn't sure if the timing was properly adjusted. I'm guessing it isn't because the engine has some hesitation when you hit the gas and it doesn't really seem to rev very high. I drove it around my yard and it didn't seem to have any power. How can I check to see if the timing is right on it? Can I just use a timing light? And also if it isn't right how exactly can I adjust it? I have access to a lot of tools and a timing light but I've never used a timing light before. If it isn't the timing what can I check that might be causing this? I changed the spark plugs and wires, thermostat and changed the oil in it yesterday. It doesn't seem to be leaking any fluids whatsoever and it fires right up and runs reasonably smooth, I can't really hear any misfires. I would really appreciate any help you guys could give me!
Thanks- Cory
Thanks- Cory
