the 2.3 in my truck is toast. It on its last leg before I did the SAS, motor has way to many miles. But overall it runs ok as long as I don't try to go down the highway any faster than 60mph. I can't use overdrive just doesn't have enough power.
I was planning on useing 33's but I got a good deal on the 35's. I am using 4.56 gearing in the axles so that helps some.
i've got an 8.8 with 4.10 gearing and my little 2.3 pulls my 33's right along pretty good. can keep freeway speeds fine, just have to hit 3rd to keep it up at 70 going up the really steep grades. Just don't be scared to let her run way up there and don't expect 25 MPG.
i'd say about 220,000 about now. Not the original motor so i can't be sure. But it's not a power house that's for sure. Like you 5th gear is downhill only gear. haha. And to do 70 im about 5200 rpm in 3rd gear.
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
