jaycal
- Aug 1, 2009
1994 4.0 Explorer 150+k miles
My wife found she had a coolant loss problem about 2 weeks ago. Truck did get hot to lead her to checking the coolant. She started maintaining the coolant level in the bottle and continued to drive it with no issues for a couple weeks. The other night she ran to the store and when she came out found coolant leaked under the truck. I went and checked it out and found the plastic radiator had split above the lower hose. Topped of the coolant and she drove it home the 2 miles without it getting hot. It was late and she needed the truck in the morning so I replaced the radiator that night with a 2 core vice the 1 core that came stock. Other than the shroud fittment a little off (1 1/2" gap down the vertical edge on drivers side) figured 2 core would be better and it was all that was available at 10 pm.
Since then the truck
Runs rough almost like a miss
Still consumes coolant
Temp gauge "bounces" around between Cold line and middle of range
Temp does not get hot at all
Check engine light is on (not sure when that happened)
With some visual trouble shooting I found
Oil looks good on dip stick (not milky or creamy)
Coolant looks good (no signs of oil or bubbling when running or cold)
At start up it appears to have a little more than normal moisture from the exhaust pipe, and very light sign of white smoke.
No other signs of visual coolant leaks external
Some of the testing equipment and techniques are not my strong point nor do I have the equipment, but I have had motors apart on a few occasions.
Any help on where to go next would be much appreciated.
Thanks
J
Thanks
J
