Calitecas
Hey, whats up guys....hopefully someone can help me out with this...
I just bought and installed a remanufactured "Cardone" steering pump from orielys, I as well replaced both pressure and return line with new ones. I filled the pump with Mer/Dex ATF Valvoline and bleed the system. I started everything up and the whine is louder then the original pump.
I've read several of the other posts on what type of fluid to use but I'm a little confused on which is better. I went on to the cardone website and found that they reccomend Mer ATF.
I used Mer/Dex ATF would this make a difference in whine?
When I bleed the system I lifted the front end and turned the steering wheel lock to lock refilling while I turned.
Would bleeding by; removing the return line and emptying it in a bottle while refilling the pump, all the while having the truck running make a difference in whine?
So far all fittings are fine, no leak, no lines touching any other part of the truck. Truck drives fine all except that pump whine.
If anyone has any idea on my whine problem please let me know. I'll be at work till late (11Pm California) but when I come back I'll reply to anyone who posted...thanks....tc
