- Dec 18, 2008
Would a sport trac body fit on a ranger frame?
With enough fab work a Ranger will fit on a 1/2 or even a 3/4 ton frame, so I don't see why the same wouldn't be true of a Sport Trac.
On the other hand you are probably asking "Can I just grab this Sport Trac body and bolt it right to a Ranger frame?", in which case I would guess the answer is...
no.
Now if you managed to talk RSH into hooking you up with one of those Mexi-can 4-door ranger frames, you might have some better luck.
What's the ultimate goal here?
I just finished putting a cummins 4bt in my ranger, and found out the wife is pregnant, need room for the car seatI did the avm lockout hubs on my ranger and from my research is not an option on the explorers.
Plus I had to do some fab work to make the cummins and allison automatic fit, just wondering how much work it would take to swap bodies.
Thanks for the info
are those Central/South American 4 door Rangers the same Ranger we get here or is it one of the rebranded Mazdas?
