- Jun 14, 2008
- Wilmington, VT
- (01) / [94] / {
how would i go about this? theres 3 fuel lines on the rangers frame.. i know one is the sender, one is the return and i have no clue what the third is.. and i know i only need 1 with a carb
i have a pressure regulator and a electric fuel pump out of the donor BII.. i was just wonderin if there would be some way i would be able to use the stock pump and just block off the return line and have the sending line go into the pressure regulator?
thanks
thanks
