Trailrated92
- Mar 11, 2008
UPDATE FIXED AND RUNNING GOOD Ignition Problem
'92 Ranger 3.0 Automatic
Running fine, driven once or twice a week for the last several months. Overdue for a tune up so I took advantage of the warm up in the weather and take care of it today.
I drove the truck last night and started it right up this morning and moved it in front of the garage. Changed the plugs, plug wires, coil, cap and rotor. Now she wont start
Have fuel psi, checked at the schrader valve on the rail, and even if I didnt have that, she wont even fire on a shot of ether down the throat of the throttle body, not even a hiccup.
Have a nice fat spark confirmed at the plug.
The rotor can only go in one way, so I cant see how it could be 180 out.I replaced it pointing in the EXACT same spot as the old one was in when I pulled the old cap off.
Coil plug connector is greased with diaelectric grease and tight on the correct terminals ( pos to pos, neg to neg )
I've checked the firing order and plug wire orientation at least 5 times, if its wrong Im a moron.
Im literally at my wits end now, as I cant find or think of a plausible reason why she wont fire back up. I didnt touch ANYTHING else. I suppose it could be the ignition module that mounts on the radiator support , but I would be shocked if it went bad at the same time I did my parts replacement today , the odds of that would seem to me to be astronomical.
The terminal on the cap marked number 1 is just towards the passenger side at the firewall, between 11pm and 12am if looking down at it from above, this is where I've been told it should be at.
The only other thing I can think of is the number 1 was molded into the wrong location on the cap. I even tried that by shifting all the plug wires at the cap 1 terminal clockwise, no such luck.
ANY IDEAS GUYS ????
I called a friend of mine who is a Ford Master Tech, but he lives over two hours away so trouble shooting on the phone was the only option for him.
He said he thought he remembered something about the early 90's 3.0's having a problem with jumping their timing when shut off. But I just cant believe thats what the problem is, happening at EXACTLY the same moment that I decide to do a tuneup ? It would seem I would have a better chance at hitting the lottery and getting struck by lighting on the same day as to have the timing jump on the day I do a minor tune up.
Im really in a bind here fella's. Because of this we are now down to ONE vehicle with a family of six, AND we are supposed to be moving to another State in a few weeks, so needless to say Im in the doghouse with the wife to say the least !!
Any ideas or suggestions will be greatly appreciated, if you live in South Jersey and can fix this thing, I'll buy the beer and pay you to come to me !
ANY IDEAS GUYS ????
