Oil pressure isn't constant. It goes up with RPM and down (a lot) with oil temperature.
It's also possible you aren't listening to 2.9L lifter tick. A lot of people will assume that every noise is the lifters. Any reciprocating part of the engine can tick, including solenoids (such as fuel injectors), pistons, loose rocker arms (2.9Ls are adjustible), and so on. Even an exhaust leak right at a head port can sound surprisingly similar to a tick (then, it will depend on throttle position, temperature, load, and a bunch of other things).
