ready to install explorer leaves...
-Nathan-
Saskatoon, SK, Canada
Hey guys, so I picked up a set of 1996 (4 door) ford explorer (4 leaf pack) leaf springs. They were in pretty good shape, so I just took out the centre pins, put new ones in (pin down) and new bushings. I also gave them a coat of red rust paint for good measure. With them i have a set of belltech shackles. Im installing them tomorrow, and Ill let you all know exactly how much lift they gave me.
im thinking you will get around 4-5 inches of lift
well i currently have a set of worn out ranger leaves...crappy extended shackles and STACKED blocks....2 inch plus 3 inch....I am eliminating the 2 inch block, and replacing the shackles with bell techs. Hoping to be an inch or 2 higher than what i am now even though im getting rid of the 2 inch block.
i have some too gotta wait for my buddys car to get outta the way though before i put it in
I paid 50$ (canadian) per leaf, plus 3$ for 2 new pins, and 3$ for a new bushing. All the old bolts came out except for one, which had welded itself inside the bushing. I just heated it up, and pounded out teh whole thing, then pressed in teh new one.
If for some reason once i get them in, i want more lift or more payload ill just order an add a leaf.
Oh, and as a side note, when you take out the centre pins, MAKE SURE you have clamps on either side, theres a lot of tension on those things.
I'm hoping you'll get 3-4 inches of lift. Thats what I want to do with mine because my Leafsprings are shot. and im doing a 4" superlift in the front shortly.
I know mine is a BII, but once I added the Explorer leafs and Belltech shackles it took mine to 4.5" lift in the rear. My stock leafs were beat though. I also did chop the eyes on the Explorer main leaf and add my stock main leaf.
Edit: Here is a pic:
If you take out that block and swap springs you will probably gain 0-1".
thats what im hoping for plumcrazy. Ill let you guys know today. Oh, and thanks again for that skid plum...its sweet.
No prob.
I'm thinking your on drugs.
The Explorer leafs in a Ranger will give you a MAX of 1.5". More than likely, you will see about .5" to .75" difference.
i got 2.5 out of mine plus a 2 inch shackle that around 4-5
If you got 2.5" out of your Explorer leaf springs, then your Ranger leaf springs were shot.
